Go Back   Ford Truck Fanatics > Special Interest > Motorcycle/ATV
  #1
Old 03-20-2016, 08:43 PM
fatherdoug's Avatar
Torn CV Boot
Is this a job I can tackle myself? The right front boot is torn in half. This is the second one I bought. 2004.5 Polaris Sportsman 400 AWD.
What all is involved in replacing the boot?
'78 F-150 Lariat
Quote:
Quote:
  #2
Old 03-20-2016, 08:48 PM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
I did one on my Suzuki... Not a huge deal. Make sure the kit you get has new clamps. Pull the wheel and hub and pop the axle out of the pumpkin. Take the old boot off and attach your new one
-Frank
Quote:
What's your view on sheep?
  #3
Old 03-20-2016, 08:50 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Piece 'o' piss.
Typically:
Remove wheel
Remove castle nut/cotter pin
Remove shock/strut
Possibly remove brake caliper/disc
Yank whole axle shaft assembly out
Buy OEM boot kit
You might want to buy a CV joint seperator tool...I will go and find a pic of the one I have.
You will need a banding tool for the band.
Clean all old grease out...prolly Moly based...wear gloves and use brake kleen
slip boot and bands on....fill cavity with grease (should come with kit)
New circlip on axle shaft where it goes into diff (should come with kit)
Reverse for assembly.
Quote:
Quote:
Quote:
  #4
Old 03-20-2016, 09:00 PM
fatherdoug's Avatar
Thank you, both. I will buy a boot, w/accessories and attempt. Yes Duncan, the grease appears to be Moly-based, by appearance. Do I need a spring compressor for the strut, or does it come out as one unit?
'78 F-150 Lariat
  #5
Old 03-20-2016, 09:05 PM
DNFXDLI's Avatar
Admin
I'm not sure as I have never done one on a PoPo...I would guess that it comes out as an assembly.
Ryan might know.
I would suggest you buying the shop manuals...I got the ones for my machine and they have been beyond helpful.
  #6
Old 03-20-2016, 09:07 PM
SuperCab's Avatar
Super Moderator
Super Moderator
Duncan's explanation was a little more thorough than mine
-Frank
  #7
Old 03-20-2016, 09:12 PM
fatherdoug's Avatar
Quote:
Ryan might know.
I will look for one.
Quote:
'78 F-150 Lariat
  #8
Old 03-21-2016, 06:43 PM
mrxlh's Avatar
mrxlh mrxlh is offline
Oilfield Trash
mrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond repute
The strut remains attached to the machine and will swing out of the way, you just loosen the lower ball joint pinch bolt, knock out the ball joint and the strut will move out of the way. Several ways to change the boot, you can use a speed boot, or disassemble the CV joint. Do a search on youtube, there are tons of video's about axles.
Quote:
Originally Posted by shurewhynot
Any man over 30 that doesn't have a belly is either a pro football player, or gay
Had to look that up, never really cared for that type of music.
Lester
08 F350 PSD Lariet, CC, LWB, 4X4, DRW, White
Stock
When Dodge and GM build something that will compete with the F450, we'll talk.
  #9
mrxlh's Avatar
Oilfield Trash
You should be able to find a manual to download for free.
Lester
Stock
  #10
Old 03-21-2016, 10:08 PM
fatherdoug's Avatar
Thank you, Ryan. I found a manual on ebay, which is on it's way. I got everything apart, slipped the new boot on the axle, and I got the small end of the boot clamped in place. I can't get the large one clamped together. I've been working on that for the last two hours.
'78 F-150 Lariat
