bugeye01
Bill
1995 E350 Crew Cab, 460, automatic. How do I determine the correct, original number for the engine computer? The local shop I took it to for an engine running issue did fix the issue, but in the process told me the control module had been replaced at some point with an incorrect one. The only problem I notice is that the "Check Engine" light often comes on and stays on. It resets when turned off and does not leave a diagnostic code behind.
