Home | Gallery | TOTM | New Posts | My Threads / My Replies | Links | Sponsors | Calendar | Arcade | Calculators | Fliers |
Thread Tools | Display Modes |
85 6.9 glow plug killer
Is being on too long the only thing that can kill a new glow plug?? Thanks |
Sponsored Links |
The only thing besides junk glow plugs is having power applied too long, making them heat up too much. Now if ether or such were sprayed in after the glow plugs had heated, it would definitely case damage to them, as well as motor problems potentially.
My trucks: The workhorse, 86 F250 4x4 6.9 nat aspirated, 3.25 exhaust, custom intake, electric fuel pump, otherwise well used stock... not real pretty but just loves to work! The other heavy hauler, 92 F350 2wd dually crew cab, flatbed/toolboxes, 92 Cummins VE 12V with intercooler, NV4500 manual The beater: 88 F250 4x4, 5.8 5 speed The project ... 1978 F150 4wd shortbed 351 auto ASE certified parts specialist I do most all of my own work so I know who to complain to..Roger |
So I thought I was hip to the problem...the controller would cycle like it should , it just wouldnt stop cycling...I thought for sure I found out what was killing the glow plugs for the previous owner..I also figured as long as I ran under the hood and unhooked the controller from the relay I would stop any premature glow plug failure.. (once it was running) Apparently this is not the case..I have managed to kill all the plugs. the funny story is this happened to the last two owners..ANd the controller had been replaced.. So even though the controller never stopped cycling it would switch on and off the proper amount of seconds..It never left the plugs on continously. I will most likely still wire a switch in, but at this point I need to understand what killed them ? ALL? unless cycling on and off even at the correct intervals on a warm/running engine would do it??? its possible that could have happened. Want to be certain before I go dump more cash on glow plugs BTW i had 4 AC delco and like 2 motor craft and 2 others came from NAPA i think..Now they are all dead Thanks in advance for any help PS I think I am having and alternator problem as well...The field seems to be putting a drain on the battery and I am getting flickering lights..not sure if thats the regulator or the diodes/alt itself..the onboard ameter seems to read fine, have to put the volt meter on it Last edited by we287gn; 04-11-2012 at 08:32 PM. |
#4
Have you tested the "dead" glowplugs out of the truck? Hook hot to the connector and ground the thread body, if its hot, they're good. DO NOT TOUCH THE ELEMENT TO FIGURE OUT IF THEY'RE HOT. I would bypass the controller, like I have, completely.
http://www.oilburners.net/articles/glowplugbypass.htm |
#5
The glow plugs do not need to be on any more than to start it, and then a little bit after. If they continually cycle, it will shorten their life just like starting it and only running it for a short time for a lot of times would. They will generally heat up and burn out if held on continuous, regular constant cycling really isn't much different, and if you consider the heat of combustion in there as well, it is pretty warm.
The ground side small terminal probably is just for the light, hadn't thought about it. That is not the proper way to control the relay though, and really, not that effective. If done correctly, the ground side will have no effect, as it grounds through the base, that little wire is not enough capacity to handle the duty of energizing that big relay. The glow plug relay works just like the starter relay/solenoid on the fender.
#6
Really has me baffled Again wonder if this is an engine thing or electrical...cant see how it can go wrong.. Two of the plugs were swollen at the tip again as well Again thanks for all the help, hopefully can figure this out soon BTW new regulator and alt seems to be charging fine...so far fingers crossed |
#7
You can use a simple resistance meter to find if they are burned out, no continuity means they are burned out. The wire size to the small terminal side is not an issue, as it does not draw much amperage through to simply move the contacts inside the relay. Some relays like that require the ground terminal like you describe, so may be the case here. In the case of a starter solenoid/relay, it is used to keep from turning the vehicle over if either the clutch isn't depressed in the case of a manual with a clutch safety switch, or an auto not in neutral or park.
Engine conditions won't cause the tips to swell, that takes enough heat to cause other significant damage. By any chance has the glow plug harness been replaced? I mean the heavy wires that go to the glow plugs themselves. The original wires on these trucks were a resistance wire, and will burn out the glow plugs if a full 12v is applied. I don't recall the actual value, but I want to say they are only 6v plugs. I do know that if somebody replaced the original wiring, it will kill plugs very fast. I have heard suggestions of finding military spec plugs, but not always the easiest to do. Military vehicles tend to be spec'd at 24v, so you can apply a full hit on them, and not burn them up. I have no clue where to find such, or if they exist for IH motors.
#8
did a little searching online , it seems i am not alone in this problem not just 6.9 ..some 7.3's toasting all the plugs in short time...most answers were use only beru/motorcraft plugs....but i have a hard time swallowing that one only because i owned an 86 and never changed glow plugs in the 4 yrs I had it and previous owner replaced only a few over the years and he always deals with whatever napa gave him...think they may have been champion ..not sure..but defiantely mixed bag.. on my 85 this is something that happed to the previous owner as well..and he has owned the truck since new, it was only in the real later years that the glow plugs started letting go like this, but i will try to investigate the harness idea..thanks Last edited by we287gn; 04-13-2012 at 06:16 PM. |
#9
How long did you hold the button down for this morning?
#10
I held them.on for.apx 6-9 quick.seconds in fear of leaving it on too long..I got those numbers frok the 86 shop manual. Also called my bud who was the previous owner of my old 86 that never had trouble.he sId he used autolite and champions. And in 4 yrs of owning it I never had a glow.plug issue As of right now I am not buying into the brand thing..too wipe em.all.out..mixed bag of brands..there is something else going on.here.. I was reading about the injector timing being.off.but I know.nothing about or have the special tools to.check.it |
Thread Tools | |
Display Modes | |
