2010 Ford Taurus Sunroof
Hey,
Does anyone know about sunroofs or anything specific about this issue? It will do the "Tilt" feature and go up. But it won't roll back on the track. If you hit the "Slide" button to move it back, you get a click and silence follows.
Is this thing off the track or is a motor burned up or something?
Big Jim F150
73-79 Ford Trucks Rock
How's your fuses? Another thing you might want to check is your slide switch, as well as your connections to see if they're tight and clean, both at the switch and the motor end, and also check your motor to see if it's burned out, as well as your drive linkage or belt to see if it is intact. Hopefully this will help you.smiliegitrdonesmilieFordlogo
