Go Back   Ford Truck Fanatics > General > Garage and Tool Zone
Garage and Tool Zone Tool discussion, or anything pertaining to your garage.
  #21
Old 03-01-2013, 01:06 AM
kiwi f150's Avatar
kiwi f150 kiwi f150 is offline
kiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond reputekiwi f150 has a reputation beyond repute
Here you go Alvin - this is a frame i made earlier this week to pull the wheel bearing and ABS ring from a rear axle shaft on a 1996 toyota surf (fourrunner??) - the ring on top of the frame is an old spacer ring that i turned one mm from the centre so as to be able to press the new bearing and spacers plus ABS ring back onto the axle shaft.
P.S don't laugh too much at the welding skills.
I converted this from an old whitworth open ended spanner just last week to remove the fuel shut off solenoid from the injection pump on another toyota hilux 3.0 litre diesel ...... probably took me about 3/4 hour of cutting and grinding to get this specific shape otherwise it would have been about 4 hours to remove the injection pump and replace it.
Cheers Mark
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rapidly promoted by mainstream media, which holds forth the proposition that it is entirely possible to pick up a piece of sh*t by the clean end."
  #22
Old 03-01-2013, 08:49 AM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
Quote:
Originally Posted by DNFXDLI View Post
Just ordered a DeWalt DCT418 scanner.....could be a very cool tool.
http://professional-power-tool-guide...radar-scanner/
Cool! Wish I had one of those...
Sent from my iPhone using Forum Runner
-Frank
Quote:
What's your view on sheep?
  #23
Old 03-01-2013, 04:02 PM
Alvin in AZ Alvin in AZ is offline
Alvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud ofAlvin in AZ has much to be proud of
Your homemade puller is cool as anything! And the modified ring is just the
sort of thing a DIYer makes instead of buying the whole (expensive!) set. :)
Quote:
bearing and ABS ring from a rear axle shaft on a 1996 toyota surf - the ring
[img]http://www.fordtruckfanatics.com/gallery/data/500/medium/2013-03-01_19_39_2
5.jpg[/img]
Cool! :)
That's what I'm talking about! :)
That little piece of open end wrench is cool too. :) Got a couple cut-off
wrenches around here where someone had cut 'em off using the corner of
a bench grinder just like that. LOL :)
Opening up open-end-wrenches is pretty common, got a few where others
had done it and got a few where I done it. My favorite is an old Herbrand 37
wrench. ...was 1+1/4" & 1+1/16" ...opened up to 1+5/16" & 1+1/8". :)
1+5/16" = pitman arm nut
1+1/8" = (3/4" nuts and bolts) inside the coil springs on my '75 F150
I'm not all the way sure but I believe it's now a 37A wrench? :)
There it is right above the "pickle fork"...
One thing's for sure it worked great at reaching between the coils in the coil
springs and loosening those spring retainer nuts! :)
Did that in '81? Anyway that wrench (with no sizes and just numbered) was
old then. LOL :) Gave a dollar for it at an "old time" hardware store. :)
Let's see some more! :)
Anybody! :)
My welding?
...got two choices...
coat hanger and gas
or
6011 "farmer" rod
xD
Alvin in AZ
ps- Ever check out Alloy Artifacts? :)
Here's a 37 wrench, but someone opened it up to a whopping 1+7/16" &
1+1/4" and it looks like hell, IMO... LOL :)
http://home.comcast.net/~alloy-artif...ch_cropped.jpg
Fig. 7. Herbrand 37 1-7/16"x 1-1/4" Open-End Wrench.
pps- "Cool! Wish I had one of those..." - SuperCab
One grandfather was an orphan he said...
"wish in one hand and spit in the other and see which one fills up first"
  #24
Old 05-14-2013, 01:34 PM
bair.leland's Avatar
bair.leland bair.leland is offline
bair.leland is on a distinguished road
So cool I had to get patent DES 377140
  #25
Old 05-14-2013, 06:11 PM
Quote:
Originally Posted by bair.leland View Post
At first I thought is was just a guy named Bair ripping out his roof when it was
supposed-to-be him just moving-a-couch "the easy way" from an upstairs room. xD
Easy as anything you can make your own and they'll be better cutters too... !
Alvin in AZ
  #26
Old 05-14-2013, 06:42 PM
dustybumpers's Avatar
owned by Fords
The coolest inline flairing tool you'll ever use
http://www.google.com/url?sa=t&rct=j...46471029,d.dmQ
Charlie
  #27
Old 05-14-2013, 07:50 PM
yep done that to except carried a couch up 1 story ladder across porch roof and through the window. Anyway I thought this was a cool tool post. This tool makes wood shingle tear offs a Breeze!!!!!! After all about the only other
tool that u can have in each hand and get more done than with just one
would be a wrench? You should see this in action at an old lath and plaster wall when remodeling. Not advertising just the best pic & info for what it does
  #28
Old 05-14-2013, 07:59 PM
And if that's not cool. Is this
  #29
Old 05-15-2013, 03:56 AM
m78's Avatar
m78 m78 is offline
m78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond repute
Two of those roof pictures , where the guys are lined up like dominoes . Top one falls and takes out the next three.
Mark
  #30
Old 05-15-2013, 01:09 PM
amkatt1's Avatar
amkatt1 amkatt1 is offline
amkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond repute
Quote:
back in the day.... all harnesses now, workers compensation will have your ***!
Roy
yeeooow!
