Go Back   Ford Truck Fanatics > General > Garage and Tool Zone
Garage and Tool Zone Tool discussion, or anything pertaining to your garage.
  #11
Old 04-11-2017, 02:16 PM
Matt LaClear Matt LaClear is offline
Matt LaClear is on a distinguished road
Have you tried something like yet? Might save you a heap of trouble.
Looking for a plug and play IDM at well below dealer pricing that is guaranteed to get you back on the road and keep you there? We'd love to help you out!
  #12
Old 04-11-2017, 07:42 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Quote:
I bought one of these about a year ago for a not-ford, since it stays parked in the street, and I don't want to run a cord. After 6 months of sitting in the street, the car started right up. I was impressed, so I bought one for my '78 ford, since it stays parked in the street also.
It was a 1.8 watt solar charger from NAPA for $36.00. The beauty of the '78 is that the cigarette lighter is hot all the time, so I just plugged the charger into the cigarette lighter. Easy Peazy.
The newer cars don't have an active cigarette lighter when the ignition switch is off, so I used alligator clips from the inside to the battery(provided).
Here is the caveat; these are NOT intended to charge a battery, but rather to maintain a fully charged battery. A full battery charge is necessary before using the solar powered charger.
Thus far, I'm impressed.
Cool Doug, glad to hear that it's working out.
Quote:
Originally Posted by Ole Green View Post
Father Doug, sounds like you are being a bit shy. Your truck is beautiful, don't be afraid to parade her around more often! I think you would have no need for a battery charger. But on that subject has anyone done the research on the solar panel requirement to maintain a bank of travel trailer batteries?
The issue is that a battery sitting will self discharge regardless....so keeping a trickle charge on it prolongs the battery life.
When it comes to solar panels, esp. for RV applications, you need at least a bank of two that are series wired and then feed a charge controller. Batteries ideally need at least 3 levels of charge....bulk, absorb and float....those voltages (for a 12V battery) will range from around 13.5 to 14.8.
So you have 2 panels with an OCV (open cct voltage) of say 35 volts in ideal conditions that might drop off to 10 under cloud...so no way that the batteries are going to get a charge.
With 2 in series, they are fed into a bucking converter (reduces voltage) with a high effeciency (>97%) to enable the batteries to get an ample charge.
That is the simplified version.
Quote:
Quote:
Quote:
  #13
Old 04-11-2017, 08:26 PM
mrxlh's Avatar
mrxlh mrxlh is offline
Oilfield Trash
mrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond repute
So if I read this correctly a battery tender and extension cord.......
Quote:
Originally Posted by shurewhynot
Any man over 30 that doesn't have a belly is either a pro football player, or gay
Had to look that up, never really cared for that type of music.
Lester
08 F350 PSD Lariet, CC, LWB, 4X4, DRW, White
Stock
When Dodge and GM build something that will compete with the F450, we'll talk.
  #14
Old 04-11-2017, 08:37 PM
DNFXDLI's Avatar
Admin
That is by far the cheapest way to go!
I'm eyeballing 4 235 watt panels for the Bird, but given the use, the genny will suffice for now.
  #15
Old 04-11-2017, 08:41 PM
mrxlh's Avatar
Oilfield Trash
Yep, gas is cheap, the payback on panels and electronics would be somewhere between Obama's America and Never.
Lester
Stock
  #16
Old 04-11-2017, 08:44 PM
mrxlh's Avatar
Oilfield Trash
Your application (and mine for that matter) we would be better off with 8 6V's, peak with the genny in the AM for an hour, and again in the evening for an hour. Run the genny anywhere in between for heavy load stuff. Then do all the high tech crap to the batteries at home on purchase power.
Lester
Stock
  #17
Old 04-11-2017, 08:48 PM
DNFXDLI's Avatar
Admin
Got 6 6V in it factory, parasitic load is big...8a/hr.
We will see what happens. Will be replacing the exisitng ones with 4 6V L16 Surrette S550's this year regardless.
  #18
Old 04-11-2017, 08:53 PM
mrxlh's Avatar
Oilfield Trash
WTF pulls that much? Fridge?
Lester
Stock
  #19
Old 04-11-2017, 08:59 PM
DNFXDLI's Avatar
Admin
Quote:
Relays.....propane solenoid.....inverter on standby...I could kill most stuff during the day if I'm not in it and don't need heat, but at night it's not an option.
  #20
Old 04-11-2017, 09:00 PM
mrxlh's Avatar
Oilfield Trash
Honda EU2k?
Lester
Stock
