Go Back   Ford Truck Fanatics > General > Garage and Tool Zone
Garage and Tool Zone Tool discussion, or anything pertaining to your garage.
  #11
Old 03-22-2017, 08:04 AM
fatherdoug's Avatar
Thank you guys for the "experience" advice.
'78 F-150 Lariat
Quote:
Quote:
  #12
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Quote:
Originally Posted by dustybumpers View Post
Learn with the gas, it will give you a better weld, and be easier
Flux has to have a CLEAN surface, and is very unforgiving. Welds will not stick, and that is frustrating when just starting out
Make sure to get extra box of tips. and go ahead and buy the big roll of wire.
The small roll don't last as long as you want it too, and is expensive in the long run
Get a tip cleaner.
Have fun, and be safe
Very accurate and true. Flux wire is OK but iis much harder to use. Likes to make little piles of bird poop welds or BB's.
Click for weather forecast
________________
Randy
  #13
Old 03-22-2017, 07:47 PM
dustybumpers's Avatar
owned by Fords
Quote:
And the welds break.
If you reverse polarity in the machine, it's better, but just use gas, and learn right , right from the start
Oh, and don't weld in the wind........
Charlie
  #14
Old 03-23-2017, 01:24 AM
Sparky83's Avatar
Sparky83 Sparky83 is offline
Virginia Chapter member
ive welded oxyacetylene.. stick.. mig, flux core and tig... i liked them all, didnt really have problems with any of them.. for the machine your looking at there its a good starter machine.. and will handle alot of small to some medium sized jobs.. like others have said.. if your going to do mig youll want to get the shielding gas bottles... theyre really not all that expensive and come in several sizes.. and migs very forgiving.. gassless flux core is usually better when welding larger projects.. such as metals at and over an inch thick..
one thing you didnt mention is what your eventually planning to weld with it..
Shawn
2004 3.9L V6 Mustang
-John F. Kennedy
-Christopher Titus
  #15
Old 03-23-2017, 01:42 AM
fatherdoug's Avatar
Thank you. I just want to learn how to weld. Most projects would be small involving iron. For example the brace for the steps into our 5th wheel camper broke off because they had just been spot welded at each corner, and a very shoddy job at that. I want to weld the brace for the full length of the step, so it is more sturdy, etc., etc.
'78 F-150 Lariat
  #16
Old 03-23-2017, 07:09 AM
owned by Fords
Mig, gas. grind, and clean everything, and weld in 1/4" spots. jump back and forth an inch at a time to keep it from heating up. heat = warping
Paint everything all purrdy when yer done........
Charlie
  #17
Old 03-23-2017, 10:46 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
I agree with all said
Quote:
Quote:
Quote:
  #18
Old 03-23-2017, 11:40 PM
cbaker65's Avatar
cbaker65 cbaker65 is offline
cbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond repute
Oh ,don't forget to protect your eyes ,don't think you will beat that flash...
YOU WONT!
It is very painful!....
CB
Im not a bum,Im on vacation!....
  #19
Old 03-24-2017, 07:03 AM
Fellro's Avatar
Fellro Fellro is offline
Admin
Think about 10 pounds of sand rolling around inside your eye sockets, and you will get similar to what flash burns feel like. Which is why the autodark helmets are good, but make sure to buy a good one as the cheapies are worse than head flipping...
My trucks:
  #20
Old 03-24-2017, 01:05 PM
fatherdoug's Avatar
I'm learning a lot, guys. Thank you!
'78 F-150 Lariat
