Go Back   Ford Truck Fanatics > General > Garage and Tool Zone
Garage and Tool Zone Tool discussion, or anything pertaining to your garage.
  #11
Old 08-06-2016, 10:22 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Spray the blue shit on and then try the reverse bit...and...as much as this may or may not need saying....drill needs to be in reverse to make reverse bit work.
Just did this with my neighbor on his old Honda bike..then ran a couple of taps through it starting with a smaller one and going slowly.
YMMV.
Quote:
Quote:
Quote:
  #12
Old 08-06-2016, 10:23 PM
DNFXDLI's Avatar
Admin
Quote:
That made me laugh.
If nothing else, I can at least provide snickering material
  #13
Old 08-06-2016, 10:24 PM
fatherdoug's Avatar
Thank you, sir. I retract the statement about your steaks......
'78 F-150 Lariat
Quote:
Quote:
  #14
Old 08-06-2016, 10:29 PM
Lorddurock's Avatar
Lorddurock Lorddurock is offline
Lorddurock is a splendid one to beholdLorddurock is a splendid one to beholdLorddurock is a splendid one to beholdLorddurock is a splendid one to beholdLorddurock is a splendid one to beholdLorddurock is a splendid one to behold
can we get a picture of the problem area?
-will untempering the easy out work? heating the bolt and easy out cherry and letting i cool rather slowly so you can drill again
-is drilling it out/ cutting off the weld nut and back nutting an option
-is the bolt broken of flush, sub flush or does it stick out?
i hate borken bolts!!!
this might make you fell better took 13 hours to drill, tap and heli coil and match a new cap to the worn major on this D8
"Everyone thinks of changing the world, but no one thinks of changing himself." tolstoy
"May you live your life as if the maxim of your actions were to become universal law" Immanual Kant
00 Vw jetta 2.0
77 f150 429
83 Buick century 4.3 diesel (lost to young fun)
-and many others
  #15
DNFXDLI's Avatar
Admin
I wouldn't...I thrive on shit and abuse..that's why I hang out here
  #16
Old 08-06-2016, 10:40 PM
fatherdoug's Avatar
The bolt is flush. I can't get to the nut because it's on the back side of the bracket. It looks like the nut was welded in place, and then the bracket was welded onto the axle housing. And I don't have any way to heat the bolt, other than a propane torch? Wow, I thought I had it bad.
Quote:
'78 F-150 Lariat
  #17
Old 08-06-2016, 10:46 PM
fatherdoug's Avatar
Might be able to get a picture on Monday or Tuesday.
'78 F-150 Lariat
  #18
Old 08-06-2016, 10:55 PM
DNFXDLI's Avatar
Admin
If you contemplate using heat Doug...use MAPP...and before anybody says it, yes the original methylacetylene doesn't exist..but the gas in a perverted mix does...and it's hot.
  #19
Old 08-06-2016, 10:58 PM
fatherdoug's Avatar
Is it still called MAPP gas? We used to have that plumbed into the power plant.
'78 F-150 Lariat
  #20
Old 08-06-2016, 10:59 PM
DNFXDLI's Avatar
Admin
Still called MAPP Doug....just not real MAPP
