Go Back   Ford Truck Fanatics > General > Garage and Tool Zone
Garage and Tool Zone Tool discussion, or anything pertaining to your garage.
  #1
Old 03-27-2016, 12:38 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile CowboyBilly9Mile is offline
CowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond reputeCowboyBilly9Mile has a reputation beyond repute
FORScan V2.3.0 has been released!
Users of FORScan already know that the software can be used to program PATS, but the big deal about this particular update is this....
+ New section - Configuration and Programming (requires extended license)
+ Programming function "Module configuration" for:
all vehicles without central configuration, for all modules except PCM
FORScan is about as close to having Ford IDS as you can get, and it's a work in progress that is getting better and better every day. So on that note, you may discover a hiccup along the way when you try to use programming. However, I can say from experience that their development and support team is exceptionally dedicated and nothing short of being absolutely outstanding. I can also confirm that FORScan has been successfully used to solve a common problem, that being, programming after changing tire size and restoring speedometer/odometer accuracy.
Enjoy the update!
-Bill
-Life is far too short to be serious all the time. So if you can't stop and laugh at yourself along the way, give me a call and I'll do it for you.
04 Ranger Fx4 Level II, 5R55E, Sonic Blue Pearl, loaded.
Useful Ford Vehicle Resources:
Owners Manuals >>> http://www.fleet.ford.com/partsandse...owner-manuals/
Build Information (click on "vehicle") >>> https://www.etis.ford.com/
Wiring schematics and TSB's (click on "technical information") >>> http://bbbind.com/
Repair guides, includes schematics w/connector pinouts >>> http://www.autozone.com/repairinfo/r...nfoLanding.jsp
  #2
Old 03-27-2016, 10:05 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Cool Bill!
Quote:
Quote:
Quote:
  #3
Old 03-28-2016, 06:11 AM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
The older version worked well. I'll ha e to download the update.
Click for weather forecast
________________
Randy
  #4
Old 03-28-2016, 11:28 AM
Quote:
I'm curious to hear your thoughts on it.
-Bill
  #5
Old 03-28-2016, 04:26 PM
smokey's Avatar
hitech hillbilly
Admin
I'll download it tomorrow and give it a try. I have a CEL on in the focus. it's a temp sensor on the thermostat it needs a new thermostat (Housing sensor and thermostat all in one unit) stupid thermostat is 150 bucks that's plain crazy.
________________
Randy
  #6
Old 03-28-2016, 05:23 PM
Some 4 cyl Rangers did this too, and yes, it's about the same $ (insane). Maybe Rockauto to the rescue for this one?
-Bill
  #7
Old 03-28-2016, 07:53 PM
smokey's Avatar
hitech hillbilly
Admin
Yeah its only like 90 on rockauto.com
I went out to get a thermostat and the guy behind the counter pulled it up and went holy hell that's expensive. Pulled up the pic and said I know way now.
It only tips the cell with the under temp code once every month or two.
________________
Randy
  #8
Old 03-29-2016, 10:08 AM
O'Rattlecan's Avatar
O'Rattlecan O'Rattlecan is offline
O'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond repute
What is FORScan?
  #9
Old 03-29-2016, 11:22 AM
Quote:
Originally Posted by O'Rattlecan View Post
What is FORScan?
Quote:
...FORScan is about as close to having Ford IDS as you can get
http://forscan.org/home.html
Think of it as a premium scan device for DTC's; this because it will not only pull the OBDII codes that all cars 1996 and new have, but it will pull the enhanced Ford codes (ABS codes are enhanced, and most of the common scanners can't access them). Or said another way and for example, access PID's such as body and chassis codes (Bxxxx and Cxxxx, x is a number). Ford techs get IDS + VDS; Forscan and an ELM or other adapter are about as close to this and at a price anyone can afford. Puts some power in your hand and much more than units such as the Torque app, Ultragauge, scangauge, etc.
There's things it can do, I suggest looking around their website.
-Bill
  #10
Old 03-29-2016, 03:27 PM
cool.
I always wonder the limits of these things. The one thing I dream out is flashing my 1994's pickup computer to tune the modifications. It wouldn't take much but I wondered if there was something that could do this short of a ford tech or a new computer ordered.
Sounds like this thing is an awesome reader but stops before writing data.
