Go Back   Ford Truck Fanatics > General > Garage and Tool Zone
Garage and Tool Zone Tool discussion, or anything pertaining to your garage.
  #1
Old 02-06-2015, 08:04 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
More garage projects.
Ran pipe today for a couple of reversible 56'' industrial ceiling fans and installed same.
I really don't like ceiling fans but there is a 20 degree difference between the ceiling (13') and the floor....adjusted the minimum setting and left them on low.
Made a substantial difference already.
Also ran power properly for Vac
Ran power for fridge and microwave as well....tomorrow will build a cabinet for the fridge so the microwave can sit on top of it.
Quote:
Quote:
Quote:
  #2
Old 02-06-2015, 09:10 PM
fatherdoug's Avatar
I like the reversing switch on the controller. That's handy.
'78 F-150 Lariat
Quote:
Quote:
  #3
Old 02-06-2015, 09:15 PM
DNFXDLI's Avatar
Admin
It is....those fans have the start winding brought out....a person could do it themselves with a DPDT switch wired as a reverser, but for an additional $15 built in, it was a no brainer.
Next is caster replacement on the engine stand and wheel dollies.
  #4
Old 02-07-2015, 12:44 AM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Nice job as usual. Another trip to caster world is in your future.
Click for weather forecast
________________
Randy
  #5
Old 02-07-2015, 05:02 AM
m78's Avatar
m78 m78 is offline
m78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond reputem78 has a reputation beyond repute
I like the remote switch too, makes it handy.
Have you added up all the BTU's those LED's put out.?
Mark
  #6
Old 02-07-2015, 09:40 AM
DNFXDLI's Avatar
Admin
Quote:
Thanks Randy...and already been
Got half swivel and the other half "total lock" swivel, urethane rated 250#.
I can't even see a BTU rating on the AA sheet....I would say very low, you can put even the fleshy part of your inner arm on the lamp and it's not hot.
They run a hell of a lot cooler than the CFL's as well....as a side note, when we replaced the house 65BR30's with the equivalent LED's the A/C ran less and the room where we often sit was noticeably cooler.
  #7
Old 02-07-2015, 11:46 AM
amkatt1's Avatar
amkatt1 amkatt1 is offline
amkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond reputeamkatt1 has a reputation beyond repute
Nice Duncan!
Roy
yeeooow!
  #8
Old 02-07-2015, 12:01 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
That is something I need to do eventually... 16' ceilings are not conducive to equal heating... Also would help with the floor sweating.
My trucks:
  #9
Old 02-07-2015, 07:36 PM
DNFXDLI's Avatar
Admin
Quote:
Originally Posted by amkatt1 View Post
Nice Duncan!
Thanks Roy.
Quote:
Left it overnight....now a 4 degree difference as opposed to 20.
  #10
Old 02-07-2015, 07:46 PM
DNFXDLI's Avatar
Admin
I'm not a carpenter....but this turned out not bad....13 ply Birch for strength.
