Go Back   Ford Truck Fanatics > Superduties & Other Trucks > Bronco
Bronco Full Size Bronco Discussion
  #61
Old 12-26-2016, 07:12 PM
fatherdoug's Avatar
Noice!
'78 F-150 Lariat
Quote:
Quote:
  #62
Old 12-26-2016, 07:30 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Looks good.
Click for weather forecast
________________
Randy
  #63
Old 10-12-2017, 09:29 PM
Bruners4's Avatar
Bruners4 Bruners4 is offline
Bruners4 will become famous soon enoughBruners4 will become famous soon enough
I've done a bunch of work over the last few weeks. I'll try to list it all out.
New SS Brake Lines, New brake hoses, New Master Cylinder, New rear wheel cylinders, New calipers, New rear drums & brake shoes & hardware, New drilled and slotted rotors & pads.
New Front driveshaft U-Joints, New front axle U-Joints, New ball joints, New Poly axle pivot bushings, New poly radius arm bushings.
Cleaned and repacked front wheel bearings with all new seals. New rear axle seals, New Ford Racing LSD carbon clutches.
New rear tail lights with retro-fit LED bulbs, LED bulbs in high mount brake/cargo light.
After the front end alignment and seating in the new brakes, I'm just about ready for the winter season.
'96 Eddie Bauer Bronco, leather, 5.8L, 3.55 LSD, Bilstein 4600's, DC XC 33x10.5x15, K&N stock replacement, 460 intake tube.
They call me Dave FSB Member
