Go Back   Ford Truck Fanatics > General > Garage and Tool Zone
Garage and Tool Zone Tool discussion, or anything pertaining to your garage.
  #1
Old 05-01-2011, 09:57 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Press
Been putting it off for some time now, but the reality is I need a press. Got it narrowed down to 2 units. If I was going to use them in a shop environment, I would look at different ones, but seeing as I know what kind of use it will see one of these should be adequate:
http://www.northerntool.com/shop/too...ct_35394_35394
http://www.gregsmithequipment.com/10...s-p/ht0813.htm
Quote:
Quote:
Quote:
  #2
Old 05-01-2011, 10:05 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
The one I have is like the first one from northern tool.
I only have a 40 ton might be a 60 and all the bearing separates and other attachments use it way more that I ever thought I would.
Click for weather forecast
________________
Randy
  #3
Old 05-01-2011, 10:16 PM
DNFXDLI's Avatar
Admin
Any issues with it?
  #4
Old 05-01-2011, 10:19 PM
smokey's Avatar
hitech hillbilly
Admin
None what so ever had it 8 years or so.
________________
Randy
  #5
Old 05-01-2011, 10:22 PM
DNFXDLI's Avatar
Admin
Thanks Randy!
  #6
Old 05-01-2011, 10:25 PM
smokey's Avatar
hitech hillbilly
Admin
Grab a couple extra sets of arbor plates the heavier the better. You will bend the cheap ones pretty easy.
________________
Randy
  #7
Old 05-01-2011, 10:27 PM
DNFXDLI's Avatar
Admin
Roger that...seen it happen!
  #8
Old 05-01-2011, 10:49 PM
O'Rattlecan's Avatar
O'Rattlecan O'Rattlecan is offline
O'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond repute
Uh, what does it do?
  #9
Old 05-01-2011, 10:53 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
I was going to ask what you needed that much pressure for... 40 typically is enough. We didn't even have anything more than that at Twin City Fan for us to use. 100 ton is more in the stamping needs range. At some of the stamping facilities we did have 100 ton rotating presses... those were monsters.
My trucks:
  #10
Old 05-01-2011, 10:54 PM
smokey's Avatar
hitech hillbilly
Admin
Press stuff real thin.
You use them to press out bearings, assemble things, bend stuff and crack walnuts
________________
Randy
