Go Back   Ford Truck Fanatics > General > Garage and Tool Zone
Garage and Tool Zone Tool discussion, or anything pertaining to your garage.
  #21
Old 02-19-2008, 11:26 PM
mrxlh's Avatar
mrxlh mrxlh is offline
Oilfield Trash
mrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond repute
Drill sharpening angle is 59-1/2 deg, the hex of regular nuts placed flat to flat is 60 deg included. The drill should "fit in the "V" the 2 nuts makes and be centered. This ensures that one land of the bit is not longer than the other (which will make a bigger hole than the drill diameter) This will not gauge the relief, just the lands.
Quote:
Originally Posted by shurewhynot
Any man over 30 that doesn't have a belly is either a pro football player, or gay
Quote:
Originally Posted by DNFXDLI View Post
Had to look that up, never really cared for that type of music.
Lester
08 F350 PSD Lariet, CC, LWB, 4X4, DRW, White
Stock
When Dodge and GM build something that will compete with the F450, we'll talk.
  #22
Old 02-19-2008, 11:57 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
It also will keep you from making the angle too steep, reducing the effectiveness of the bit, and keeps the angle the same. Good tip, been wanting to make a good gauge, that will work!
My trucks:
  #23
Old 06-13-2008, 09:23 AM
john112deere's Avatar
john112deere john112deere is offline
Super Moderator
john112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond reputejohn112deere has a reputation beyond repute
Empty laundry detergent bottles work great for storing and transporting smaller quantities of used motor oil. (One jug per oil change, roughly, in my case.)
Just make sure that when you're trying to remove the spout, you don't also remove the threads for the cap.
Easy to come by, usually big enough to hold a bit, don't seem to degrade, and have a nice handle to carry them to the truck with.
-Ian
1997 Ranger XLT 4x2, 2.3L 4-cyl 5-speed -- 2009 Ranger XLT 4x4, 4.0L V-6 5-speed -- 1986 BMW R80
The advantages of modern engineering are in many ways over balanced by the disadvantages of modern civilization.
--Col. W.A. Roebling
  #24
Old 03-31-2009, 06:23 PM
mrxlh's Avatar
Oilfield Trash
Been a while since someone posted, got one that I used the other day. For a level that will go around corners, make long distances or from one side of a truck to the other (obstructed) use a piece of clear tubing and water, a drop of food coloring. Add a tee in the middle with a valve to "adjust" height. This can also be used to make a cheap water/mercury manometer.
Lester
Stock
  #25
Old 03-31-2009, 06:27 PM
mrxlh's Avatar
Oilfield Trash
All rubber seals can be a pain to install, dish liquid slides them right on and dries not leaving a lubricant behind.
Lester
Stock
  #26
Old 04-01-2009, 09:50 PM
mrxlh's Avatar
Oilfield Trash
Need a glue for tool box drawer liners? CAT Glue, How about for the magnets that fall of of parts trays? CAT Glue. Gaskets that move when assembling parts? CAT Glue. WARNING it takes damn near a jack hammer to get gaskets off after this is used, or a bench grinder with a wire wheel to get it off your hands. If applied correctly it will seal the world.
Lester
Stock
  #27
Old 04-01-2009, 10:07 PM
Truckin4life's Avatar
Truckin4life Truckin4life is offline
Texas Chapter Leader
Truckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond repute
I usually use New (Read: CHEAP) ATF, but noisey ratches. Sockets wrenches and anything of the like will get a over night or a couple of days of a good soak every once in awhile...
Keeps your tools looking good as new, and your ratches quite, one thing i cant stand is a noisey ratchet...
Come Join the TEXAS CHAPTER!
Bacon is GOOD!
1995 F-250 "stock" 351winnie, zf5 and 37" rubbers....
(KIA)
Don
  #28
Old 04-01-2009, 10:45 PM
1985 Ford F-150's Avatar
1985 Ford F-150 1985 Ford F-150 is offline
Country Boys Can Survive
1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute1985 Ford F-150 has a reputation beyond repute
I always put mine in 90wt.
Dan
72 F-250 4x4
67 CJ5
86 F-250 HD 4x4
79 Bronco
  #29
Old 04-01-2009, 10:48 PM
mrxlh's Avatar
Oilfield Trash
Tools rusting a little, stop it by throwing them in a bucket of diesel fuel.
Lester
Stock
  #30
Old 04-01-2009, 11:02 PM
Hmm Ill need to try that one the salt got to mine in the bed toolbox I got.
Dan
72 F-250 4x4
67 CJ5
86 F-250 HD 4x4
79 Bronco
