Go Back   Ford Truck Fanatics > General > Garage and Tool Zone
Garage and Tool Zone Tool discussion, or anything pertaining to your garage.
  #1
Old 05-31-2007, 10:47 PM
mrxlh's Avatar
mrxlh mrxlh is offline
Oilfield Trash
mrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond reputemrxlh has a reputation beyond repute
Garage tech tips
I'll start this, then if anyone wants to sticky or tech folder this, cool, everyone post their homegrown how to's here.
My first one is on drill sharpening, any 2 hex nuts placed together is close enough to use as a gauge for hand sharpening a drill bit. More to come.
Quote:
Originally Posted by shurewhynot
Any man over 30 that doesn't have a belly is either a pro football player, or gay
Quote:
Originally Posted by DNFXDLI View Post
Had to look that up, never really cared for that type of music.
Lester
08 F350 PSD Lariet, CC, LWB, 4X4, DRW, White
Stock
When Dodge and GM build something that will compete with the F450, we'll talk.
  #2
Old 05-31-2007, 10:56 PM
mrxlh's Avatar
Oilfield Trash
Tech tip #2
ATF, brand or type not important, is just about the best drilling and tapping fluid for all metals.
Lester
Stock
  #3
Old 06-01-2007, 07:47 AM
blacksnapon's Avatar
blacksnapon blacksnapon is offline
Super Moderator
Super Moderator
blacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond repute
I'll give it a try, hang on to your worn 1/2 wrenches. A 1/2 wrench is 12.7 mm, worn out, it will work for a 13 mm.
ase master tech--fmc senior master tech (retired)
  #4
Old 06-01-2007, 10:49 AM
mrfixit's Avatar
mrfixit mrfixit is offline
Chief Chaotic Engineer
Location: Malfunction Junction, Fidelity MO -or- Mound City, KS
mrfixit has a reputation beyond reputemrfixit has a reputation beyond reputemrfixit has a reputation beyond reputemrfixit has a reputation beyond reputemrfixit has a reputation beyond reputemrfixit has a reputation beyond reputemrfixit has a reputation beyond reputemrfixit has a reputation beyond reputemrfixit has a reputation beyond reputemrfixit has a reputation beyond reputemrfixit has a reputation beyond repute
Afraid of getting oil or atf stains on your pristine garage floor? lay out a sheet of TYVEK house wrap, logo side up, before you pull your vehicle in to work on it. It won't allow liquid to soak thru and will take a beating with jacks/creepers/thrown tools and squirming mechanics that paper won't.
Is that a Ford, or are you just happy to see me?
There is no heaven on earth, but we can arrange for an early delivery.
If at first you don't succeed, reload and try again.
-Tom, 98 F150 Lariat 2wd 3door / 84 E350
  #5
Old 06-01-2007, 10:57 AM
mrfixit's Avatar
A section of 1/2" hardware cloth will make a nice grate over your Oil Pan to help keep you from having to fish the plug out if accidentally dropped.
  #6
Old 06-01-2007, 06:43 PM
mrxlh's Avatar
Oilfield Trash
Tip for removing #2 phillips head screws that have a tendancy to strip out. Take a small ammount of valve lapping compound and put it in the head of the screw. It will make the screw driver "bit" into the screw. Also clamping a vise grips on the shank of the screw driver and pushing down on the end of the screw driver helps to keep them from stripping out.
Lester
Stock
  #7
Old 06-02-2007, 08:40 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
A large trash can lid with the removable center plug makes a great funnel for the bigger messy jobs like trans filter replacement or radiator removal where it runs on the frame and everywhere...
  #8
Old 06-02-2007, 08:50 PM
Super Moderator
Super Moderator
Quote:
Thats good! I used once a fiberglass spare tire cover off a conversion van with holes drilled in it.
  #9
Old 06-04-2007, 10:38 AM
mrfixit's Avatar
I keep fishing line in my toolbox, so that when I go to unthread or rethread a bolt in a particularly difficult location, I loop a length around the threads wind it a few times... the remainder around a finger. after the bolt is out/sufficiently started I simply pull it loose to tighten it down. This way I don't drop the bolt.
I'm clumsy enough that I NEEDED this solution, and it works on the smallest of fasteners.
  #10
Old 06-04-2007, 10:43 AM
mrfixit's Avatar
Sometimes When I have a bolt or a screw in an inconvenient location I use a section of vaccuum tubing to start it. I keep short sections of a few different sizes around, and I slip it over the head of the fastener and use it as a flexible driver.
