2004 Chrysler Sebring 2.7 engine R&R
384
i was just wondering if anyone has done a engine R&R on one of these cars before..
i may be doing one for a friend here soon..
she is a high school friend... well actually known each other since 2nd grade.
but anyways.. she's tight on money and a shop quoted her 2800 bucks..
HAHAHA worked up the math according to book time and at 65 dollars an hour after everything including a used engine and all parts oils etc.. it's sitting at like 1700 bucks..
anyways... back to original question,
anyone ever done one before??
Aren't they part way under the cowl? If so, it is lift required. Chrysler led the way on that format. The 96-newer vans are that way, no room to get to even the back valve cover without removing the intake. Haven't had the displeasure of doing one of them though, so it may be different than I am thinking.
Yep, it is an out the bottom type.:
2.7L Engine
Before servicing the vehicle, refer to the Precautions section.
Properly relieve the fuel system pressure.
Drain the engine oil.
Drain the cooling system.
Recover the A/C refrigerant.
Remove or disconnect the following:
Negative battery cable
Throttle body air inlet hose
Air cleaner assembly
Both front wheels and splash shields
Lower front fascia from the crossmember
Lower air shield from the crossmember
Front fascia
Upper radiator crossmember
Upper and lower radiator hoses
Transmission oil cooler lines
A/C lines from the condenser
Radiator, fan and A/C condenser
Transmission electrical harness connectors
Transmission shift cable
Engine electrical harness from the Powertrain Control Module (PCM) and bulkhead connectors
Antilock Brake System (ABS) brake module from the lower radiator crossmember
Brake line from the lower radiator crossmember
Both halfshafts
Front engine mount through bolt
Front engine mount from the lower radiator crossmember
Lower radiator crossmember
Drive belts
Power steering pump and bracket. Do not disconnect the lines
Heater return hose from the right front frame rail
A/C compressor electrical connectors and reposition the compressor
Structural collar
Exhaust system cross under pipe
Rear engine mount and transaxle bracket
Torque converter housing cover and match mark the bolts
Positive battery cable from the Power Distribution Center (PDC)
Ground cable from the left side transaxle mount bracket
Throttle and speed control cables
Coolant overflow hose
Heater hose
Ground strap from the right shock tower
Fuel lines
Brake booster and vacuum purge hoses
Engine ground straps
Loosen the cradle engine mounts and lower the engine/transmission assembly onto the dolly.
Remove the vertical engine mount bolts
Slowly raise the vehicle and make certain that the cradle is positioned properly.
Secure the engine/transmission assembly to the cradle and remove the assembly.
To install:
Position the engine/transmission assembly under the vehicle and slowly lower the vehicle into position.
Continue to the lower the vehicle until the right side engine mount and left side transaxle mount are properly aligned.
Install or connect the following:
Mounting bolts and torque them to 45 ft. lbs. (61 Nm).
Raise the vehicle and remove the cradle
Fuel lines
Ground strap to the right shock tower
Heater hose
Ground cable to the left transaxle mount bracket
Positive battery cable to the PDC
Torque converter bolts and cover
Structural collar
A/C compressor to the bracket
A/C compressor clutch electrical connectors
Heater return hose to the right side frame rail
Drive belts
Front engine mount to the lower radiator crossmember
Both halfshafts
Brake line to the lower radiator crossmember
ABS module to the lower radiator crossmember
Engine electrical harness to the PCM and bulkhead connectors
A/C lines to the condenser
Front bumper fascia and lower air shield
Splash shields and both front wheels
Air cleaner assembly and throttle body air inlet hose
Fill the engine with clean oil and replace the filter.
Fill the cooling system to the proper level.
Recharge the A/C system with the proper refrigerant.
Start the vehicle, check for leaks and repair if necessary.
Holy crap like I told her id have to look at it more to decide if I was able to do it.
This was all at like 10 last night
That $2800 sounding more reasonable now??? HAHAHAHA.
