Go Back   Ford Truck Fanatics > Superduties & Other Trucks > Superduty Gen.1
Superduty Gen.1 1999-2007 F250, F350, F450, F550
  #41
Old 08-02-2016, 11:41 PM
Sparky83's Avatar
Sparky83 Sparky83 is online now
Virginia Chapter member
shes got all 6 feet back on the ground again.. but havent test driven her yet.. thatll be tomorrow to see if i reassembled her correctly... hope i did..
Shawn
2004 3.9L V6 Mustang
-John F. Kennedy
-Christopher Titus
  #42
Old 08-03-2016, 12:58 PM
Sparky83's Avatar
lil dually didnt disappoint me.. i drove her to work today and while she did ride alot smoother than she had been.. when i looked under the truck for leaks.. i noticed one of the universal caps is now half out of the axles ear upside it got trapped against the ball joint... but now im going to have to macgyver it to get it home to fix it again.. looks like somewhere along the way it lost the C clip that holds it in..
Shawn
-John F. Kennedy
-Christopher Titus
  #43
Old 08-03-2016, 01:42 PM
fatherdoug's Avatar
Oops!
'78 F-150 Lariat
Quote:
Quote:
  #44
Old 08-09-2016, 12:59 PM
Sparky83's Avatar
since i forgot to finish my updation of the ujoint replacement...
Axle shaft was returned to its home...
cleaned up the back of the Wheel hub.. then re-greased the axle bearing there..
wheel hub back in place...
thanks to my 3/4" ratchet and tq wrench snugging the nuts to 133ft-lbs was easy...
brakes back on...
hub lock reinstalled (much easier than it was the first time trying to do that...)
different lighting..
wheel on and ready to go... or so i thought..
When i got to work i saw this during an inspection for leaks...
the stupid c-clip was defective... popped out of the groove and moved up the cap as the cap was getting knocked out...
MacGyver fix to get it home... replaced the c-clip and a little grinding.. problem was solved...
Shawn
-John F. Kennedy
-Christopher Titus
