What did you work on today
heavydoc
Instigator
70
WNC
Let's see what everyone is working on.
Went out to a Takeuchi excavator with hydraulic leaks an saw this before I even stepped outta my truck
Sparky83
5,567
219
Norlina NC
i unloaded 6 pallets... 4 of them in housewares and 2 of them in candy....
heavydoc
Instigator
70
WNC
I bet we couldn't, hardly touch the stuff after eatin a whole pan of fudge when I was around 10 or 12
Sparky83
5,567
219
Norlina NC
I bet Doc and I could eat a pallet of candy.
i keep trying to sell a case when people walk by when im loading the shelfs... yet to get any takers... lol
Blue-Truck-Nut97
crank polisher
551
18
Still making sporadic progress on the Allis Chalmers. Drained the muck out of the gear boxes and refilled, greased everything, found a couple failed fittings covered in silver roofing tar. Drained 6 gallons of water out of one of the drive chain cases, repaired wiring, found the hub nuts were finger tight, removed 2 broken lights, installed 6 more, removed 12 feet of wire from inside the cab while installing new lights.
But on the bright side, the jack we saved from the scrap bin works great! Funny what a little oil will do.
heavydoc
Instigator
70
WNC
Finally fixed this winch. Another shop “rebuilt” it an left out pieces. With no manuals I had to reverse engineer it. This was going in to replace the brake dump spool an install the missing spring
2 Mack’s , 2 6.ohs
White Mack had a bunch of brake work on it ( again)
The blue one needs service , air leaks fixed . Door doesn’t open on the drivers side . I noticed a wheel seal leaking .
The white 6oh is getting a delete and oil cooler . The blue 6oh has something wrong with it that has yet to be determined...
heavydoc
Instigator
70
WNC
Put the right bucket cylinder on a 844 K2 today, pulled and rebuilt it yesterday.
Sparky83
5,567
219
Norlina NC
I cleaned the trucks windows inside and out... the outerside looked like a bug massacre happened on them.... they seem to like flying towards the lights at night.....
Blue-Truck-Nut97
crank polisher
551
18
Finally done with this thing. Lights up like a shrimp boat now.
On to the aluminum flatbed that got a pair of loader forks stuck through the floor.
smokey
Hitech hillbilly
I was out on a hunt for a new ride today. I got rear ended Oct 31 and they totaled the car. Found nice looking lariat till I saw the swiss cheese frame. Well the hunt will continue.
Sparky83
5,567
219
Norlina NC
i like the blue one there....
