Go Back   Ford Truck Fanatics > F-Series > Generation 5
Generation 5 1967-1972 F100, F250, F350
  #1
Old 08-08-2016, 01:44 PM
GregoYatzee GregoYatzee is offline
GregoYatzee is on a distinguished road
Electrical problem
Charging issue in my old FrankenFord. My truck is an early 70's box turned into a dump truck. Base is an f350 and cab is 1970 f100. I've found two related wiring schematics, this is the one that matches my wiring... http://www.fordification.com/tech/wi...350_master.jpg (sorry for the outside link...) Nothing has been changed the 8+ years I've owned the truck except for the random replacement of the fuse link. The last several months I have been trying to sort this problem as it seems to have gotten worse. I installed blade fuse holder and even replaced entire fuse box with blade fuses. No change to problem. All grounding seems ok. Replaced voltage regulator, same. Tried a spare alternator, same, both bench tested good. One thing I have discovered is charge voltage is 22-24 volts, which I assume answers the blown fuse. I can't say I understand how system works but lack of stater connection confuses me.
  #2
Old 08-08-2016, 02:00 PM
cbaker65's Avatar
cbaker65 cbaker65 is offline
cbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond reputecbaker65 has a reputation beyond repute
Quote:
My lands.....
A 70 model doesn't take that much juice ,its got to be a ground somewhere,
maybe a body ground to chassy or a naked wire short ,like to any lights!
CB
Im not a bum,Im on vacation!....
  #3
Old 08-08-2016, 05:49 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Sounds like the voltage regulator is bad,but I see you replaced it.
Click for weather forecast
________________
Randy
  #4
Old 08-09-2016, 02:47 AM
Lorddurock's Avatar
Lorddurock Lorddurock is offline
Lorddurock is a splendid one to beholdLorddurock is a splendid one to beholdLorddurock is a splendid one to beholdLorddurock is a splendid one to beholdLorddurock is a splendid one to beholdLorddurock is a splendid one to behold
is the voltage regulator well grounded? maybe check to make sure the wiring is good from the regulator to alternator? wires have less hen 5ohm resistance
was a new solid state regulator installed or an older spring type?
maybe were the source voltage for the regulator is lower only in that area causing higher outputs though out the rest of the system. voltage regulator still getting feed from starter relay ( i think that were it should get its feed, but im not sure)
just ranting out ideas
"Everyone thinks of changing the world, but no one thinks of changing himself." tolstoy
"May you live your life as if the maxim of your actions were to become universal law" Immanual Kant
00 Vw jetta 2.0
77 f150 429
83 Buick century 4.3 diesel (lost to young fun)
-and many others
  #5
Old 08-09-2016, 11:10 AM
In the process of trying to eliminate possible bad wire... removed all radio wiring, cut feed to roof lights, pulled all fuses... V regulator has ground wire cleanly bolted to it, will sand a rust free spot under its mount bolts. I believe I have wires narrowed down to a select few. When I unplug the wire going to stater terminal on VR, Truck starts without blowing fuse, but of course, doesn't charge. That wire runs to dash and branches off several places on way to ignition. I suspect a naked wire short, which is why I've removed all the shade tree radio wiring.The dash harness looks to be fully wrapped and intact. How can I best test wiring in harness under dash without pulling it all apart? Oh yeah, I replaced the ignition switch too. All the parts were replaced last summer and it seemed to work ok for a while. Thing usually sits most of the winter.
