Anyone recommend a good multipurpose jack?
hi everybody, so new to the diesel/full-size game, was looking at the Hi-Lift style jacks, but I'm pretty sure my longbed/reglar cab F350 is too much for those, thought I saw a heavier-duty version somewhere, no luck yet searching the interweb. I do have the stock bottle jack, but I was hoping to get something else, interested what other have used with good results, thanks.
I'd get a decent size hydraulic bottle jack and call it good; Thats what I did but so far I haven't had to use it, even put in the same spot for the factory one..
The high-lift jacks will work, but are not the safest in my opinion, they fall over easy. Be best to get either a bottle jack or floor jack. Depends on your other uses, as in other vehicles, you may be better served by a regular rather than low profile floor jack. I have both, and on trucks, the low profile does the job, but with not much lift left over. When I do transmissions, I go for as much height as I can get, and the low profile won't do then.
smokey
Hitech hillbilly
smilieIagree smiliewhathesaid
The handyman jacks are dangerous to say the least. I have a few of them ,they want to kick out but are very handy to have one on hand to pull or separate thinks and they will lift also.
A bottle jack or floor jack is your best bet.
I'm with Roger...only place a Hi-Lift jack has is in an emergency situation on the trail (not bad as a hand held winch either). They're awkward to deal with and not very stable, even with the larger base plate, IMO. I'd go with a standard 3-ton (minimum) floor jack with 20-22" of lift. Also invest in a good set jack stands...I wouldn't rely on a couple 1 cent o-rings.
thanks for all the input. I was leaning towards the hi-lift style because of it's "off-road" capabilities. 3-ton Floor jack would be handy, unless I'm in a ditch, lol.
Probably make do with the stock jack for now, and hope I don't need it...
I can't think of a jack out there that I would trust if I were in a ditch, so IMO that's moot. A couple strips of ply wood can do wonders for floatation with a floor jack. For the record, in my Bronco, all I carried was a craftsman 3-ton floor jack, and unless you're in mud up to your ankles or higher, it'll do just fine without the ply wood in any condition.
Agreed, I've carried a 3 ton floor jack as well; But as I've gotten oder and lazier (sp) I've stated leaning toward the bottle you can get 5 or 10 ton rated on and still take up less space in the truck than a floor jack..
Now if your pulling an engine or trans, then a floor jack is most definitely a usefull almost need tool...
Main key is to lift on something that can take it, like axles, control arms, frames and the like. Do not try to lift a little car by the rocker panel with one(if you can actually get it under them..)
I have used the hi-lift to get me out of a ditch before, by using their tipping tendency.... Got hung up, so I would lift it, then push it over, and got myself out that way.
my thought with the Hi-Lift style is that you can throw a strap around a tree, another going to the vehicle and use it as a come-along, however my trucks really too heavy from what I've read.
i will position a piece of steel {like what mark above suggested} & sandwich it between the frame & lifting portion of the bottle & center it all up,making sure the bottle is directly under the frame.and by all means use a jack stand if you have to get under it.never raise on a hill or incline & make sure you are on solid ground before you lift.
Agreed on all points, I use a piece of 2x between the jack and the frame..
Hehehehe, yep yep..
I cut some 3 1/2 " squares out of some 1/2" flat bar. About 12 of them.
They work great for keeping the piston from crushing into the wood when I'm jacking floors in houses.
Big difference between a house and a truck though.. (I know you know this, but I still had to point it out though)
You can but I wouldn't get one just because of that, a come a lonng woks just as good and takes up less room..
well, now I gotta price out come-alongs! lol
I need some more junk in the bed anyway, to offset all that engine weight.
