Go Back   Ford Truck Fanatics > Superduties & Other Trucks > Superduty Gen.2
Superduty Gen.2 2008-2010 F250, F350, F450, F550
  #31
Old 12-29-2009, 01:04 PM
Truckin4life's Avatar
Truckin4life Truckin4life is offline
Texas Chapter Leader
Truckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond reputeTruckin4life has a reputation beyond repute
sure does, also repped a few of ya in here! Holiday spirit i guess.
Come Join the TEXAS CHAPTER!
Bacon is GOOD!
1995 F-250 "stock" 351winnie, zf5 and 37" rubbers....
(KIA)
Don
  #32
Old 12-29-2009, 02:53 PM
Hanau Hanau is offline
Hanau is a jewel in the roughHanau is a jewel in the roughHanau is a jewel in the rough
Interesting. Last winter one of my guys called me up saying the 07 3500 wouldn't move. He was in 4x4 high plowing the mall and pulled underneath the loading dock to make a 3 point turn. It was dry since the dock is covered. Threw it in reverse and the truck locked up on him.
We couldn't get it out of 4x4. No force on Heaven or Earth could budge that lever and it was bound up so tight the truck wouldn't roll unless a lot of throttle was applied. Good way to break something, so he called me.
Got it loose by dropping the plow and jacking up the front end. With the front end in the air and the transmission in neutral we were able to get it out of 4x4.
Helluva deal.
My 90 F-250 is tough to get out, but a hard kick to the lever will force it back into 2 wheel.
The 82 F-150 doesn't care, well before I put Lockrights in the front and rear. Now it does need a slippery surface to get in and out.
On the 09 3500 I have the rotary knob 4x4. Sometimes the lights blink and it takes a second or two for it to shift out on pavement.
Bottom line is I don't let my guys use 4x4 on dry pavement anymore. Standing rule is to shift out of it on any hard surface.
Of course there's many different transfer cases. Gear driven, chain driven, electronic, manual, vacuum actuated. Different systems and combinations of systems will react differently.
  #33
Old 12-29-2009, 09:15 PM
Jackary Jackary is offline
Jackary is on a distinguished road
Quote:
Originally Posted by Jackary View Post
Off a different thread I read up on what cetane means etc and gather the following:
Ford says that 45 is the minimum recommended CETANE level. The minimum specs at the pumps in the States is 38 to 40.
I live in CA where the minimum is 50 so I'm guessing the booster probably would not do much for me here in CA?
Any ideas on the booster question? If I don't need booster in CA then I really want to understand that.
  #34
Old 12-29-2009, 09:24 PM
blacksnapon's Avatar
blacksnapon blacksnapon is offline
Super Moderator
Super Moderator
blacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond repute
If you trust the rating, dont use it. One things for certain, it wont hurt to use it anyway.
ase master tech--fmc senior master tech (retired)
  #35
Old 12-29-2009, 09:35 PM
Helluva deal.
I know my hubs can be tough to disengage and so can the transfer case, but just locking the whole truck down seems very strange...
Owners manual states not to use the 4wd on dry pavement...
Bacon is GOOD!
(KIA)
Don
  #36
Old 12-31-2009, 06:11 PM
6L PWR's Avatar
6L PWR 6L PWR is offline
6L PWR has a reputation beyond repute6L PWR has a reputation beyond repute6L PWR has a reputation beyond repute6L PWR has a reputation beyond repute6L PWR has a reputation beyond repute6L PWR has a reputation beyond repute6L PWR has a reputation beyond repute6L PWR has a reputation beyond repute6L PWR has a reputation beyond repute6L PWR has a reputation beyond repute6L PWR has a reputation beyond repute
How do you know if the fuel from 76 / Chevron / shell is high quality or not? When there is only one diesel pump, you don't have a whole lot of choice do you? Remember, I don't know nuttin' here. I need remedial help.
To ensure good or at least decent fuel, I pick the station where I see the most diesels filling up at. There's 8 stations in my town pumping diesel, but only one will I fill up at because I see LOTS of others using it including some commercial/fleet guys. That's where I go because I know it's the freshest.
Stuck in a freakin' 2001 GMC Yukon XL with 175,000 miles!!
WILL have another Ford Truck someday!!
