vacumn hose diagram anyone?
rambler
New Shoes......
ok, still working on a cure for the superduty..
Now it has began to stall when idleing, like turning into a street... smilieeatndrink
I also noticed on the right side of the engine.. ( left if you are facing it under the hood), there seems to be a vacumn line connection... but no hose connected to it, nor do I see a broken hose nearby... I cannot take a picture and post at this time, but its on the same side as the battery.. The truck acts like a vacumn leak,, ( e.g also the air stays on the defrost when accelerating, then goest to where it is switched to.. floor or center) till I push the gas again...
ANy ideas? I really need to get this running better,.
thanks again for all your help! BTW,, no trouble codes are present.
rambler
New Shoes......
there is no hose connected, that is the issue, its on the left side down ( where the fuel pump would be on a old 350 chevy 350, or a 232 amc 6) cars I also work on... its looks like a vacumn port connection where a hose would slip on... (looks exaclty like the ones that connect to the auto hubs.) but I cannot find any loose hoses anywere... that are not connected somewhere else.
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
If it's down that low it that maybe the vent for the vac hubs. Can you get a pic of it for us to see?
I need to see a photo . then I can look for a diagram
