Go Back   Ford Truck Fanatics > SUV > Escape
Escape Mariner, Tribute
  #11
Old 02-22-2016, 06:15 PM
SuperCab's Avatar
SuperCab SuperCab is offline
Super Moderator
Super Moderator
They should be able to test the fuel pump pretty easily. Put a pressure gauge on it and see if it's pumping up to spec or not.
Don't know what the symptoms of a bad pcv valve would be aside from some moisture buildup in the crankcase... Don't imagine it would cause drivability issues but I don't know for sure.
O2 sensor shouldn't affect cold start idle I don't think. Could contribute to your fuel consumption issue though. But the colder weather can be enough to so that on its own.
-Frank
Quote:
What's your view on sheep?
  #12
Old 05-17-2016, 06:05 PM
Matt Matt is offline
Matt is on a distinguished road
They replaced a bad motor mount, PCV valve, and 'cleaned' the MAF.
It is smoother, but the idle still drops to 500 on my onboard tach at stoplights.
I shift into neutral, and idle goes up to about 650.
Should there be that much difference in RPMs between D and N?
I wonder if they can just go in the computer and raise the curb idle....
