Go Back   Ford Truck Fanatics > Special Interest > Custom Fabrication
  #11
Old 10-16-2013, 10:14 AM
tjcustomranger's Avatar
tjcustomranger tjcustomranger is offline
tjcustomranger has a spectacular aura abouttjcustomranger has a spectacular aura about
There will be one shackle on the middle of the bumper on the bottom. But that will be okay. I need to build the base plate for the winch to bolt to I think 5/16 is what is usually used.
Tyler
1976 F-150 4WD 4 inch lift
35x15.5x15 super swamper tsl sx
360 with eddie performer and holley 4bbl
  #12
Old 10-16-2013, 10:22 AM
Warn said use 1/2 inch base plate at minimum.
Tyler
  #13
Old 10-17-2013, 09:04 PM
primetime's Avatar
primetime primetime is offline
sawmill slave
primetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond reputeprimetime has a reputation beyond repute
Quote:
Took the words right out of my mouth. The saw mill has taught me that if you think you`ll be alright, go a little heavier. Plenty of bracing is not a bad thing either. And I would put two shackles on it, in line with the ends of the frame.
________________________________________
Justin
With a little luck and a greenback dollar you gonna see me shine.
  #14
Old 10-18-2013, 12:38 AM
i'll design something the i can bolt a piece to the mounting brackets to have shackles on either side. it will have dual brackets anyway and then a few braces off of them to support the sides a bit. plus it will weigh 100+ pounds and have some weight on it from the winch and a few other things.
the warn website said 1/2 inch at minimum and you can go as thick as youy want as long as the bolts are 3/4 of an inch into the winch
Tyler
  #15
Old 11-02-2013, 05:19 PM
bumpper is coming along good but thursday i was grinding some welds flat and put more pressure on it because i had about 3 more minutes and ended up pushing the bumper over and making a dip that i have to reweld and grind off again. luckily i caught both the bumper and grinder could have been ugly. put a couple pics up shortly. they aren't the best just had my phone
Tyler
  #16
Old 11-02-2013, 05:28 PM
Here is the current progress will finish grinding it and start finishing up the brush guard Monday and tuesday
Tyler
  #17
Old 11-02-2013, 05:29 PM
Left/passenger side
Tyler
  #18
Old 11-02-2013, 05:30 PM
Right/driver this is the side that got messed up
Tyler
  #19
Old 11-02-2013, 06:55 PM
DNFXDLI's Avatar
DNFXDLI DNFXDLI is offline
Admin
Looking good
Quote:
Quote:
Quote:
  #20
Old 11-02-2013, 07:10 PM
smokey's Avatar
smokey smokey is offline
hitech hillbilly
Admin
Click for weather forecast
________________
Randy
