Go Back   Ford Truck Fanatics > Special Interest > Custom Fabrication
  #1
Old 02-18-2013, 11:12 AM
crzybil87's Avatar
crzybil87 crzybil87 is offline
C.R.A.Z.Y.B.I.L.L
crzybil87 will become famous soon enough
shackle reversal questions????
I'm planning on doing a shackle reversal on my 89 f350 , I'm redoing my front suspension on my truck I've got parts from various company's , however. How do I figure out what length shackle do I need ? Thats the only thing I seem to not be able to find is how long I need them. Any help would be awesome
89' F450
39x16x16.5 tsl's
dump truck springs for a lift
6" of lift
under construction
  #2
Old 02-18-2013, 12:32 PM
O'Rattlecan's Avatar
O'Rattlecan O'Rattlecan is offline
O'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond reputeO'Rattlecan has a reputation beyond repute
Well Crazybil, a lot of the geometry is going to change when you flip the shackle. If the standard shackle is 4", for instance, when you flip the shackle, it will raise the truck almost 8". The problem becomes the distance your driveshaft can reach, and you will likely have to move around your shackle hanger and spring hanger on your frame. This might also be enough to move the axle toward the center of the vehicle.
These are just things to think about before you commit to flipping the shackle.
  #3
Old 02-18-2013, 07:39 PM
Fellro's Avatar
Fellro Fellro is offline
Admin
My understanding is that the stock shackle is commonly reused. The length of the driveshaft isn't really so much of an issue as the angle it has from the t-case to the axle.
My trucks:
  #4
Old 02-18-2013, 08:27 PM
crzybil87's Avatar
C.R.A.Z.Y.B.I.L.L
I think you guys think I mean a shackle flip. On the front suspension I'm planning on moving the shackle from the front of the leaf springs to the rear, like how chevys are set up with the shackle in the rear of the leaf springs
89' F450
39x16x16.5 tsl's
6" of lift
under construction
  #5
Old 02-18-2013, 08:48 PM
Fellro's Avatar
Admin
Hadn't heard of doing that. I have heard of replacing the springs with normal style springs so that they arch downward. Not sure how well that will work with the TTB axle.
My trucks:
  #6
Old 02-18-2013, 09:47 PM
crzybil87's Avatar
C.R.A.Z.Y.B.I.L.L
I have a Dana 60 up front, I don't like the shackle being up front
89' F450
39x16x16.5 tsl's
6" of lift
under construction
  #7
Old 02-18-2013, 11:03 PM
Fellro's Avatar
Admin
With D60, you do want it in the back. On the TTb axles, the spring works like a radius arm. On a straight, the front hanger locates the axle. Unless you are lifting it more, I would suggest finding a shackle from an F350.
My trucks:
  #8
Old 02-18-2013, 11:19 PM
crzybil87's Avatar
C.R.A.Z.Y.B.I.L.L
Mine is a 350 do you mean find rear shackles to use for the rear shackle on the front spring?
89' F450
39x16x16.5 tsl's
6" of lift
under construction
  #9
Old 02-19-2013, 06:20 AM
Fellro's Avatar
Admin
I'm too used to 250's. I would have to defer this particular subject to someone that knows better than I do. Only 350 we have is a 2wd.
My trucks:
  #10
Old 02-19-2013, 06:46 PM
crzybil87's Avatar
C.R.A.Z.Y.B.I.L.L
Haha at least your honest
89' F450
39x16x16.5 tsl's
6" of lift
under construction
