Go Back   Ford Truck Fanatics > Superduties & Other Trucks > Superduty Gen.1
Superduty Gen.1 1999-2007 F250, F350, F450, F550
  #1
Old 08-06-2015, 09:49 PM
billrigsby billrigsby is offline
billrigsby is on a distinguished road
2001 F350 - No blower Motor/Just Defrost
Like the title says; I have a 2001 F350 with No blower Motor and Just Defrost, it is actually a friends, he is building a fence,
and I am looking into the truck problem. The just defrost is probably a vacuum issue, but I do not have any book for this truck,
so I have no vacuum or wiring diagrams. As far as the blower motor, I am thinking switch or motor, fuse has been checked?
Is there any other "control" box involved with this year/model? If anyone has ANY diagrams and troubleshooting info it would be
greatly appreciated, as would any other insight. Also any dash tear-out instructions, to make the access easier?
Thanks a ton, pun intended!
Bill
  #2
Old 08-07-2015, 07:17 AM
Sparky83's Avatar
Sparky83 Sparky83 is offline
Virginia Chapter member
Biggest question id have for you that i know others will eventually ask (plus it will help for later when Vince finds this thread).. Does the truck have the Manual switch panel (Dials/actual switches - XLT, XL) or is it the Digital Climate panel (digital display w/ push buttons for settings - Lariat (option), KR, Cabellas, ect ect). depending on which control panel he has depends on how they were controlled.
Shawn
2004 3.9L V6 Mustang
-John F. Kennedy
-Christopher Titus
  #3
Old 08-07-2015, 12:33 PM
blacksnapon's Avatar
blacksnapon blacksnapon is offline
Super Moderator
Super Moderator
blacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond reputeblacksnapon has a reputation beyond repute
When diagnosing a blower fan, think backward. To have a perfect circuit, you have power, fuse, load (fan), and a ground. The fan speeds work by supplying different amounts of ground by way of resistors. Power is usually constant. If you lose ground, you have no fan even though there's power. Look at the blower motor resistor first. A circuit tester is invaluable for electronics diagnostics.
ase master tech--fmc senior master tech (retired)
