Help identify this relay please
it is on the inner fender of my 73 F250 and 74 F150 beside the starter solenoid,
It has three pins parallel to each other in a triangle position. It seems to be pulling a 12V draw on the battery, when I connect the batt cable this relay clicks loudly, and I cannot keep the battery charged. It has three wires, I believe 2 are yellow, I am not sure of the colors at this time, sorry
thank you
That makes perfect since, as I had to disconnect the horns way back, because the contacts in the steering wheel made the horn honk when I turned the steering wheel, I had forgotten that, as I have had no time or "drive" to get this truck on the road, until my other dinosaur started to give me trouble.
Time for a horn button.
