V5...The Dents We Find
http://norfolk.craigslist.org/cto/4885157118.html
Big Jim F150
73-79 Ford Trucks Rock
More than likely in 77 it was the 351M with the NP435 stump puller 4 Speed transmission, I had one with the same specs, but with a 10 foot flat bed instead of a dump for my first vehicle. 76 was the last year of the 360/390 FE engines, and 77 was the first year of the 351M / 400 engines., unless someone swapped an FE engine in to it. Which is possible, but not likely.smilieFordlogosmilieFordlogosmilieFordlogosmilieFordlogo
Big Jim F150
Weren't the FT engines 361, 391 in the larger Ford trucks, that is larger than an F-350, more like the F-500, F-600 and up through 78. For the light trucks f-100 to F-350 from 77 to 79 the 351M / 400 used? And up to 76 the FE engines in the light trucks f-100 to F-350? Unless someone might have swapped in an FT engine, if that's possible.smilieFordlogosmilieFordlogosmilieFordlogosmilieFordlogo
You are right. The truck in question is an F500.
OOOHHHH! Extra points for black!
The door trim even matches the body trim.
Don't start another black/blue white/gold dress debate. I coulda sworn that was dark jade metallic. I do only have one contact in, and on a new computer...soooo...
