Truck sat all last winter until about a month ago. I finally kitted the carb. Found the EGR bad. Ordered a replacement from NAPA. It was bad too. Got a second, also bad. Napa refunded my 90 some bucks and I decided to leave it off. Made a plate from a 3/8x1 1/2 aluminum strap. Gasketed it place of the EGR. Removed the vacuum lines. Put the distributer vacuum advance line to the S port. I will post a diagram of the new vacuum set later. After the carb and other was back on, the 400 started right up and needed only a little tweaking by ear. Right now the truck is at a mechanic for scoping and fine tuning. Even with only tuning it by ear, it runs stronger than ever. More to report after return from shop Monday or Tuesday.
Second question area is the behind the dash panel lights. The turn socket in back of the cluster. The socket holes are wasted and the contacts are ruined. I have an alternate light for now. A little clip on reading LED flashlight. Kind of crappy, but is there a good fix for the little light behind the instrument cluster?
Hardball (as in 230 FMJ EIC competitions)
